USMA_Dad's avatar
USMA_Dad
Norcold n811 refridgerator not working
I have a Norcold n811 refridgerator and it suddenly stopped functioning. After my troubleshooting attempts I'm at a loss. The thermistor is functioning, the heating unit gets hot, the condenser fins at the top are hot to the touch, but the absorber tubes are not warm to the touch. I replaced the control panel and that did not make a difference. I have power to it and it works on ac and gas. No fault codes are being displayed. The 5a fuse on the control board was blown so obviously I replaced that. The fridge is mounted in a slide out and unfortunately the cooling fans are dead center in the back of the refridgerator and not accessible. I've been full-timing in the rig and never had a problem. The only thing I can think of is there's a blockage somewhere between the condenser fins and the absorber tubes. I tried wrapping on the tubes but nothing worked. .
Given the holiday weekend I can't get someone out here to diagnose so I welcome all suggestions and advice. Thanks in advance!
