nvreloader's avatar
nvreloader
Problem with the TH solar project
Guys
I have encountered a couple of problems with my solar project.
I am not sure just how to correct/fix or make it work yet.
Problem:
I will have 4-230W PV panels on the roof,
I will have them wired in parallel/series connections,
the spec's of these panels are,
Canadian Solar CS6P-230P Silver Frame
STC Power Rating 230W
Number of Cells 60
Voc 36.8V
Imp 7.78A
Vmp 29.6V
Isc 8.34A
NOCT 45°C
Series Fuse Rating 15A
Maximum System Voltage 600Vistics
Type Polycrystalline Silicon
Output Terminal Type MC connector Type 4
Output Cable Wire Gauge 12 AWG, 2 ft long,
Length 64.5in
Width 38.7in
Depth 1.6in
Weight 44.1lb
It is recommended to use a combiner box,
to reduce the number of pv wires to 2 wires going down to the CC,
pv wire lengths from pv panels to the combiner box is 10-12' each and then 10 to 12' to the CC.
These pv wires will run thru the reefer vent straight down to the equipment bay 10-12' below.
I want a way to disconnect the pv panels, (for any maintenance that may be required) via a fuse or CB etc.
Here lies the problem,
The electrical bay,(22"x 22"x 16") will hold all the solar stuff, CC, possible inverter, major fuses/CB, quick emergency shut off of all the solar stuff/battery bay etc.
This access door, (limited room to work thru etc) is 12" W x 6" high and is located about 12" above the floor level.
I will have all the above equipment mounted to a 3/4" board,
(size unknown yet), prewired etc, for ease of mounting and for vertical attachment to the wall etc.
Is there a way for disconnecting the pv panels at this main equipment board and still have the minimum 1-3% wire loss at the CC, without the combiner box on the roof?
Any suggestions/ideas would be greatly appreciated.
Tia,
Don
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
