- wa8yxmExplorer IIIThe old one was sort of rusted (not necessary rust but "Stuck" the new one goes in much easier.
- CharlesinGAExplorerDon't know about others, but I appreciate it when the OP reports back with the resolution to the problem. It will help someone in the future.
Charles - SlowBroExplorer IIIAfter five months, I plugged in the element and it worked perfectly, no fires :)
- SlowBroExplorer IIII ended up just using a squirt of WD-40. Got it in. Won’t be using it for a while so some of it should evaporate. I’ll keep an eye on it when I turn it back on.
SlowBro wrote:
dougrainer wrote:
If the old one came out the new one will go in.
You would think so, but it’s now even more stuck than the old. Won’t go up or down. Pulling it I had more leverage but pushing it back in, it’s now jammed. Wish I had used a lubricant :-(dougrainer wrote:
There is also a 2nd sleeve that you can use. Doug
Got a picture of that? I only see one.
it will be next to the existing one to the rear. Doug- SlowBroExplorer III
Got a picture of that? I only see one. - If the old one came out the new one will go in. Just swivel back and forth when inserting the new one. There is also a 2nd sleeve that you can use. Doug
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
