WDE
Jul 15, 2016Explorer
temporary loss of 12volt power when turning off lights.
I am having an issue with my 2005 Forest River Salem fifth wheel.
On our last trip, the 12 volt system started going completely off at times when we would turn of a light or otherwise change the load on the system.
The 12 volt system would then stay off for approximately 3 - 5 minutes then start coming back on with the lights starting out dim and then returning to normal.
We were hooked up to shore power and I camp with the coach battery disconnected (not charging) and running the 12 volt system off the converter.
I had to connect the coach battery to prevent these loss of power episodes.
Bad converter ???
Any ideas as to possible cause?
I have used this camper this way for years (coach battery disconnected while on shore power).
Any help appreciated.
Bad converter ???
