IF T-stats are reset then you need to check where 12V power stops for gas operation.
Goes from switch to high limit/normal t-stat then to module.
From module to spark electrode (and gas valve for 6-8 secs)
Could be bad ground connections
Dirty connections on module plug
Loose/corroded terminals on t-stats
Faulty high tension wire to spark electrode
Improper gap on spark electrode and ground rod
BAD module
Trace the 12V power thru circuit
