โAug-02-2018 06:46 PM
โAug-08-2018 05:59 AM
โAug-04-2018 05:35 PM
โAug-04-2018 04:04 PM
โAug-04-2018 12:48 PM
webeRving wrote:
My question is what is the solution to running the living room TV while boondocking. They install a 12volt plug in the bedroom with the antena booster which was a simple fix with my portable inverter. Then they install two 110 plugs in living room.
โAug-04-2018 11:05 AM
JCK wrote:
Doug chances are the rating on the cigar plug are for only the plug only. If thatโs a dedicated circuit back to the fuse bank and manufacture puts in a bigger fuse than the wire can handle there setting themselves up for a law suit. When I get back to my trailer Iโm going to pull that fuse and see what goes dead if only the cigar plug I will be able to check wire size
โAug-04-2018 08:25 AM
โAug-04-2018 08:05 AM
โAug-04-2018 06:51 AM
JCK wrote:
My cigarette lighter plug or more common a outlet for a 12volt tv is listed as 10 amp. Well 12 volt 10 amp is 1200 Watts more than enough amp to run a 400 watt inverter. I run my 400 watt inverter of that plug all the time. The inverter power my TV and also a Vornado Fan at the same time. Your face plate should on plug should tell amp rating.
โAug-03-2018 09:25 PM
โAug-03-2018 06:34 PM
โAug-03-2018 10:10 AM
โAug-03-2018 09:04 AM
โAug-03-2018 08:50 AM
WILDEBILL308 wrote:
Like Doug, I don't understand what all this talk of extra 12v outlets???
You hook up the inverter to power the 110 circuits you want to power off the inverter. When you have shore or generator power the inverter passes that power through and does not draw power from the batteries.
Bill
โAug-03-2018 07:58 AM
