- harolddaveExplorerI was using LED lights but I think that's a bad option.
- STBRetiredExplorerI used ProFlex on mine when I replaced them with LED clearance lights.
- WNYBobExplorerIMO you should take off the lens loosen the screws, lift up the light and apply Dicor or equivalent around the wires and screws. Then screw it down. If the lens is loose I applied a very thin coat of (God forbid) silicone, but just where the lens touches the base.
Good luck! - downtheroadExplorerProflex or Dicor lap sealant. (not the self-leveling formula).
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
