HarmsWay
Nov 11, 2016Explorer
LED clearance lights failing
I've noticed that after two years of use most of the LEDs in my rear corner clearance lights have failed. I believe they are a Bargman series #58 with 4 LEDs per unit. Of the four lights I'm down to 3 working LEDs - that's 3 of 16. Anyone else seeing this?
I popped the lens off on two of them and there was a small amount of moisture but it didn't look to be anywhere near the electronics.
Obviously it will be easier if I replace with the same fixture rather or even easier if I swap in new circuit boards. If I knew what LEDs they were using I could change those but I don't know what they are. On the other hand if these fixtures are generally known to be **** I may as well get better ones now.
Bob
Bob
