Baja_Man's avatar
Baja_Man
Propane smell inside trailer...how to best diagnose?
I am going through testing all trailer systems...refer on propane, heater, stove, oven.
Two days ago I switched refer over to propane to let it run on propane and see if it would get colder than when on 120V. It did not. It actually was 1-2 degrees warmer!
I tested stove, oven, and furnace (lighting and letting them run for 5-10 mins) and then shutting them off. I left the refer on propane overnight.
Yesterday, there is a gas odor inside the trailer. Not sure where it is coming from....stove, furnace, or refer....all of these were run on propane for testing. I thought maybe it was residual gas smell from when I was lighting the burners (it took a minute or so for propane to get to stove/oven, as they had not been lit for many months.
Today, I entered trailer and could still smell gas, so I turned off the refer and closed propane tank valve.
NOTE: I did check, before running any propane items, using soapy water in a spray bottle, the lines that connect tanks to diverter valve. No leaks at these rubber lines.
Propane detector alarm did NOT activate.
Thoughts on where this gas smell can be coming from? BTW...it does not smell like rotten eggs (read that propane can smell like this)...to me, it smells like propane gas.
I guess I could spray soapy water on ALL line connections inside trailer....stove and furnace. Furnace is installed under a couch.
Could it be refer....since it didn't get colder than when running on 120V? Maybe refer is not getting all the propane (due to a leak) it needs to work at optimum level while on propane?
Where to start? Other methods beside soapy water?
Thanks!
