biggjb's avatar
biggjb
Structual Repair with metal components
This is more a theoretical question as I have not seen posts pertaining to using steel 2x4s to replace rotten wooden ones. My camper has some significant repairs and I thought about trying to incorporate metal frame components in order to reduce weight. I can see a problem if the wooden part only needs to be partially replaced, however, if the whole component requires replacement could one use a metal component in its place? Any thoughts would be welcome.
