TPMS Tire pressure monitoring System
rtate
I just installed A TPMS System and noticed that If I leave the monitor turned on and leave my trailer, the monitor continues to report the last temperature and pressure it received when I was hooked to the trailer.
This is telling me that when towing, if it loses contact with a particular tire it will act like it is transmitting reliable data when it is the last temperature and pressure it was able to read.
This is very misleading. You could actually be running on a flat tire and the monitor is telling me everything is ok.
Is there a way to change this maybe thru a default setting?
2014 Ram CTD 4x2 SRW 3.42 68 RE auto trans
Big Horn 3055RL
Restless
San Marcos Tx
46 REPLIES 46
vic46
Just Googled "Doran Pressure Pro RV 360" and went straight to the Doran site. Followed the links to the 360 monitor with no problem!
[COLOR=]Never argue with an idiot. You will be dragged down to their level and then beaten with experience.
bfast54
fj12ryder wrote:
Well, there no such thing as Doran Pressure Pro, so that might explain why I couldn't find the Doran Pressure Pro RV 360. It may have been the original, but it is now simply Doran Mfg., and Doran RV360.
OTOH the system looks good except for the non-customer serviceable batteries on the sensors. Probably not much of an issue, but hate the idea of being out of service possibly while getting a battery replaced on a sensor, plus the hassle of packing and shipping it.
Well.......they have CHANGED THE NAME ....but if you look up DORAN ---- YOU WILL SEE THE RV360 ..
I have had it long enough ,to have a couple sensors replaced , few under warrenty,and couple I had to buy.
They ship REAL FAST ... and I have had them ship to where I was staying ,or arriving.
No hassle .......easy as pie
So up to you ------ get a system that works,---- or chance Thousands of dollars damage WHEN ( not if ) a tire goes flat.
Totally up to the RV owner
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
fj12ryder
Howard and Peggy
"Don't Panic"
bfast54
P.S.......if you see my "signature " @end of my posts it says DORAN PRESSURE PRO.:W
B&W/Companion
My Blog
Good Sam Member
bfast54
Look up DORAN PRESSURE PRO.
It is different than "Pressure pro".
Doran pressure pro IS THE ORIGINAL
Rv 360 $299.99
I did go with the antenna ----- when I bought a bigger longer trailer ..
Remote antenna #3623...$49.99.. (well worth it.l
B&W/Companion
My Blog
Good Sam Member
fj12ryder
agesilaus wrote:
fj12ryder wrote:
Nope, no luck searching for a Pressure Pro 363 either. :h
Are you using Google, it came right up for me...top of the hits:
Link
If you can find a Pressure Pro 363, or better yet a Pressure Pro RV 360 on that site you're doing better than I. 🙂
Howard and Peggy
"Don't Panic"
fj12ryder
Of course I found Pressure Pro, but I was looking for the unit described by Bfast54:
"I bought an AMERICAN MADE ...INSTANT reacting unit
Made in Ohio....it uses radio signals and if I dont turn the trailer part off... it almost instantly says I LOST A SENSER when I drive away from my 5er.
Getting the CORRECT UNIT is a big part of any purchase
I reasearched the heck out of them BEFORE purchase."
He says he researched the heck out of them, but I can find absolutely no site for his Pressure Pro RV 360. Is he referring to the Doran RV360, or a Pressure Pro system?
Howard and Peggy
"Don't Panic"
Charlie_D_
I use Bing. USed Pressure Pro RV 360 and it took me to the "http://www.rvtirepressure.com" web site which is Pressure Pro.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
agesilaus
Link
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
fj12ryder
Howard and Peggy
"Don't Panic"
agesilaus
Okay, I'm a bit confused. I can find a Doran RV360 and I can find Pressure Pro systems. But I can't find a Pressure Pro RV 360.
The new model is the 363 search using that
Superbumper
fj12ryder
Howard and Peggy
"Don't Panic"
Searching_Ut
My understanding of the tireMinder TPMS is that it waits a considerable amount of time to report signal loss as well, but I don't have one and can't personally verify that. I have noticed that your rarely see the TireMinder system sold without a repeater.
As for worrying to much about this potential failure, I don't loose much sleep over it. I did install a repeater to minimize the chance of loosing a tire while at the same time having a dropout from loss of signal. I personally think the odds of that happening are small, but given the way the system works you really don't know how common system communication problems might arise. When first starting out on a trip the temp and pressure increases you tend to see appear to be regular, and constant between the tires so my guess is the system overall works pretty good.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
Charlie_D_
agesilaus wrote:
How much was it? They don't show any prices on their website.
Go to the "http://www.rvtirepressure.com website. Click on the PressurePro Truck and Trailer link upper left. Opens new window. This one-Complete system includes the monitor, 4 sensors, antenna, power cord and mounting hardware. For trailers and 5th wheels longer than 40 feet, we recommend upgrading the antenna to either the 35 Foot Coax Cable or the Echo Repeater is the lowest priced at $405.
Thank A Veteran
Native Texan
agesilaus
Superbumper
