Mar-01-2018 04:30 PM
Mar-05-2018 09:46 AM
4x4ord wrote:Cummins12V98 wrote:
Please explain how I can load to my RAWR and NOT be over my GVWR. Why have a RAWR if I can't load to its limits.
If I load the front of my truck box with some 10" blocks and put some bags of Portland cement at the back of the box I might have placed 1400 lbs in the bed of my truck but because the heavier product is at the back I've lifted 100 lbs off the front axle. Now I hook onto my bobcat trailer that puts 1800 lbs on the ball. This removes another 500 lbs off my front axle and places 2300 lbs on my rear axle. So I've added 3800 lbs to my rear axle and removed 600 lbs from my front axle.
My rear axle is maxed out at 7300 lbs and my front axle is at 4750 - 600 or 4150 lbs. I've got my rear axle at maximum rated capacity and I'm still under my gvwr.
Edit: The previous numbers were just kind of pulled out of the air. After actually measuring the distance from the rear axle to my hitch receiver I see that putting 1800 lb of tongue weight on the rear hitch ball would transfer about 700 lbs from the front to the rear axle. So the bed of the truck could be loaded such that 100 lbs of the 1400 lbs goes on the front axle and the remaining 1300 on the rear.
Mar-05-2018 06:59 AM
Mar-05-2018 04:17 AM
For me the fact that the registered weight rating is what is used is sort of a flaw in the system.
Often the owner can decide what weight to register the vehicle at. The owner typically basis his decision on his wallet and not any real science.
Mar-04-2018 11:27 PM
Me Again wrote:Your link goes directly to a sticker that has some yellow. But the only info on that sticker is basically tire info. No GVWR at all. Also no front or rear axle ratings. Simply tire size, and pressures. But your link has many pics to look at. Some of them show the silver sticker like I have. The silver stickers have much more info on them that pertains to this conversation. GVWR AND individual axle ratings. None of the yellow ones I clicked on show anything other than tire size, pressures and what the maximum cargo should be.Huntindog wrote:Me Again wrote:I have already looked. MY 2011 sticker is 100% silver with black print... And as an aside my axle weights add up to more than the GVWR, by quite a bit. GVWR is 13K. Axle ratings total over 15K.... GM COULD have put 14K as the GVWR and stayed in the same classification... They chose not to.
BTW all recently produced vehicles and traikers have a carrying capacity sticker that is the GVWR minus the actual weight as manufactured. This sticker is yellow or the part with this info is yellow. Look again.
There must be a reason for that.
Your door placard does not contain this info?
https://www.google.com/imgres?imgurl=http://www.tirerack.com/images/tires/tiretech/checking_tire_pre...
Mar-04-2018 06:55 PM
Mar-04-2018 06:53 PM
spoon059 wrote:
Yes.:W
I don't haul commercial, but I enforce traffic law. No traffic law exists that has anything to do with the yellow sticker... The only weight enforceable options that I have in Maryland are Tire rating, registered weight rating and federal bridge rating per inch width of tire.
Mar-04-2018 06:36 PM
Mar-04-2018 06:25 PM
wnjj wrote:
Actually Washington cares about GVWR when it comes to chain laws: https://www.wsdot.com/winter/traction.htm
That’s an example of outdated laws that haven’t kept up with the times. 10,000 lbs used to mean “commercial” style trucks and not your average commuter pickup truck.
Mar-04-2018 05:32 PM
Mar-04-2018 05:31 PM
Huntindog wrote:Cummins12V98 wrote:I don't think I have ever seen a vehicle where the axle ratings added up to the GVWR. They always add up to more. Has nothing to do with a dually or classification. More to do with leeway for load distribution.
"What does confuse the issue is taxes and weight enforcement."
THIS is exactly why my Dually and all newer DRW pickups INCLUDING the f450 have 14K GVWR. If one pound over that it puts them in a Commercial classification!
Speaking of IRV2 I was kicked off there from stating my 14K was only there for licensing and tax purposes having that argument with SmokyWren I believe was the Moderators name. They actually accused me trying to sell my new truck and RV as an excuse to kick me off.
My argument was how can I have a SAE rated RAWR of 9,750# and load it to that and ONLY use my unloaded front axle weight of about 5,300# add these you get 15K.
He INSISTED I was overweight even tho I have tonnage to cover my actual 15,600# loaded truck weight.
Mar-04-2018 05:18 PM
Mar-04-2018 05:10 PM
Mar-04-2018 04:44 PM
Me Again wrote:I am pretty sure that the yellow sticker is for the trailers... Not the trucks. At least my 2011 Silverado does not have a "yellow" sticker. My 2010 TT does have one though.spoon059 wrote:
Yes.:W
10-4
Mar-04-2018 02:55 PM
spoon059 wrote:
Yes.:W
