- Cummins12V98Explorer III
schlep1967 wrote:
Cummins12V98 wrote:
RAM makes a SRW Dually
What is a single rear wheel Dually?
I know weird thigs happen. I even had a ducted split ductless A/C system installed in my house.
HAAAAAA, thanks for pointing out my brain phart. ;) - MFLNomad IISWB dually maybe?
I know weird thigs happen. I even had a ducted split ductless A/C system installed in my house.- MFLNomad IIAbove poster is correct, you need to more understand your trucks axle/tire limits. You will be at the very limit, or just over. You will need a lighter hitch than the Superglide.
While your truck could easily tow a 22K FW it could not carry that wt.
No one backs their boat, or TT to 90 degrees, and a FW is no different. A little common sense, and awareness, is your friend. That FW is tall, need to be aware of above. When turning in continuous arc, or backing tight, awareness is key. These things are learned quickly, and most know to pull ahead, straighten a little, then continue backing, no matter what you are towing. 90 degrees..NOPE
Jerry - Cummins12V98Explorer IIIOP I think you need to look at the truck specs again. It'a all in the details!
"IF" that 5er is a triple axle and it has 15% pin weight I suppose it could handle it with it's 3,300# pin weight. How does that with a HEAVY Pullrite hitch and other items compare to your RAWR???
I am assuming this RV is a double axle and the REALISTIC pin will be 4,200# at 25%. Also just because it says 16,800# it sure doest stop gaining weight! My DRV has 21k GVWR and it actually weighs 24k with a 6k pin.
Unfortunately people all the time get SUCKED INTO these so called "RATINGS".
Either start looking at DRW trucks (RAM makes a SRW Dually) or start looking for a lighter say 14k GVWR RV.
Solitude 378 MBS.
UVW1 14344 lbs
Hitch Weight1 2686 lbs
GVWR 16800 lbs
Length2 40' 2"
Height5 13' 5" - speediq99Explorer IIThis makes a lot of sense.
I think I did my homework on the truck. My truck can carry up to 22k 5th wheel and I max out at 16800. That leaves me some room and I am comfortable but I don't want to be ignorant either. Dually was an option, actually cheaper that what I got. It is just too much truck for me as a daily driver and has its limitations as I learned here. Perhaps one day...
I have seen a few pics of 90 degree action and it looks extreme. While I probably won't intentionally do that w/o correcting, it is the unintentional that I want to cover.
It is still unclear whether a sliding hitch is necessary to fully avoid cab damage with a 6 3/4 bed and a new Solitude 378. I am leaning towards the Pullrite however a comment on Pullrite maintenance is throwing me off a bit.
I am buying a new hitch so if there are better options than Pullrite, this is the time to find out :-) I want something easy to maintain, easily to hitch on and off even in uneven terrain, easy on the towing and above all safe for a short bed SRW F350.
Thank youschlep1967 wrote:
Funny how you ask about a sliding hitch and the weight police show up....
I've been using a Pullrite Superglide since 2010. I have never had a problem with it. I did make sure to read and understand the instructions that came with it. Those that don't read and understand are the ones that have problems with them.
Since I bought mine there are other options out there. If I were to be looking for another auto-slider, Pullrite would be at the top of the list but I would also be looking at what else is available.
The biggest issue I see is people not taking the time to learn how to properly back the fifth-wheel. If you are getting anywhere close to 90 degrees when backing, you either are not doing it right or you are trying to get into a spot you shouldn't be. - Funny how you ask about a sliding hitch and the weight police show up....
The biggest issue I see is people not taking the time to learn how to properly back the fifth-wheel. If you are getting anywhere close to 90 degrees when backing, you either are not doing it right or you are trying to get into a spot you shouldn't be. - speediq99Explorer IIHi Russ,
I don't think I understand your message regarding the capacity of the F350 Diesel Crew Cab 4x4 SRW.
According to Ford, it has a GCWR of 30,000 and maximum loaded 5th wheel weight up to 22,000. Can you clarify?
It is not a Momentum, it is a Solitude 378 MBS.
MCrhagfo wrote:
speediq99 wrote:
Hello,
What is the best sliding 5th wheel hitch out there?
2022 F350 crew cab diesel 6.5ft bed
Towing 14k 40ft 5th wheel
Side question, are these things easy to install if you have the holes in the truck?
Thank you
MC
I don't think Ford sells a SB F350 DRW, so you should be looking for a bigger TV, as a SB F350 SRW will only have a GVWR of 11,500# and base on your other post you have way more than a 14,000# 5er.
Grand Design Momentum 376TH, these are the specs.
UVW1 15,900 lbs
Hitch Weight 3,250 lbs
GVWR 20,000 lbs
Length 41' 3"
Height 13' 5" - JIMNLINExplorer IIIPullRite Superglide auto sliding hitch has been the gold std for many years. However where any sliding hitch is located in the bed one can still have contact with the trucks cab.
At a campground in AR I was talking with another camper about his ding in his cab even tho he had the Superglide and a chevy truck. GM has the longest C/A (cab to rear axle) so most GM owners never use a slider even if the have a manual slider.
Anywayz looking at his hitch in the bed it was set 4" in front of the trucks rear axle. That 4" brought the trailer closer to the cab on sharp turns ,especially right had turns, at a stop sign the bottom of a steep hill like many campgrounds have.
I had him look at mine that sits zero over the rear axle for max sliding capabilities. He was a newb with a truck and trailer and let the hitch installer decide where to locate the hitch in the bed. - rhagfoExplorer III
speediq99 wrote:
Hello,
Thank you
MC
UVW1 15,900 lbs
GVWR 20,000 lbs
Length 41' 3"
Height 13' 5"
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
