ret-miner
Sep 23, 2015Explorer
Changing Tires
Has anybody ever used a tire changing block that they sell that you drive one wheel up on it to lift the other tandem wheel to be able to change it
Arcamper wrote:Tin Pusher wrote:
Arcamper, question for you: After you have blown a tire on one of your two axles, how much weight is on the remaning tire?
If your equalizer works right and there is enough suspension travel the same amount there was to start with. If the tire that blows goes flat and the suspension will not let that tire drop then the full weight of that side of the trailer shifts to the good tire.
mileshuff wrote:
I see no problem with trailer being supported by one tire. Tire ratings are at 60-65mph or so and hot. They should be able to handle the load easily cold at 0mph. When one tire goes flat in most cases you're already sitting with the weight on one tire.
donn0128 wrote:
Hydraulic jack. Works for everything.
