mtofell1
Jul 04, 2016Explorer
RLS7201 wrote:
Many years ago there was a few 460 gas pushers manufactured. They had cooling problems that was falsely blamed on the engine being gas. The real problem was the engine/radiator fan. The fan pulled air instead of pushing air.
Richard
BennieH wrote:
"I wouldn't think that would be much of a problem. Diesel engines generally generate more heat than a gasoline engine because of the high compression."
Actually diesels run cooler in the engine compartment. That is why all ambulances are now diesel. There were a LOT of gas engine ambulances that had engine compartment fires in the late 90's and all the builders switched to diesels.
Interesting. I thought the switch was made because ambulances have become so large (F450 and F550 sometimes) and due to constant running / idling.
