BFL13's avatar
BFL13
Explorer II
Dec 13, 2018
Clearance Lights Leaking -Thank you For the Tip.
camperdave mentioned leaking clearance lights in another thread. Thanks to that tip, I was able to locate a mystery leak in our C at the back. I was running out of Eternabond sealing everything above there to no avail. Gottaluv this forum for good tips! Thanks. :)
  • A tip from my boating days... When you are attempting to seal anything keep in mind that the caulk product is there to form a gasket not to glue things down. You should apply the caulk and lightly tighten the screws/bolts etc., and then let it cure for 24 hours. Then after it has cured tighten everything down.
    If you apply and then tighten you merely squeeze the caulk out from where it needs to be.
    By waiting until the new "gasket" has cured before torquing down the fasteners you get a long-lasting watertight seal.
    :C
  • You should be able to seal the lights without any sealant being visible. Remove the lights and seal under them. Wipe away any excess that squeezes out.
  • One of the first things I did when I took possession of our RV is to caulk the top and sides of all of the clearance lights. That stopped the leaks but now all of the caulk is an ugly black and won't clean off. I wonder what paint would stick?
