twobags
Mar 23, 2014Explorer
KwiKee Electric Steps
I have a 2004 Allegro with KwiKee steps that will not retract with the step sw. , the door closing or the ignition bypass, has anyone else had this problem ?
Jagtech wrote:
As mentioned, most folks vote for a bad controller. But before spending the $$$, try tapping the motor with a (small) hammer while its trying to close. If it operates, then the motor is bad. Also check for a bad ground on the controller, they are known for causing issues. And as noted, keep hands and arms clear!
as said already try putting 12V directly to motor if it works then its controller or switch magnet
Cottontop wrote:
I had the same problem it was the magnet switch in the door frame. Not saying that is your problem but it could be. If you order new ones stay with the color.
