willald
Sep 01, 2020Explorer II
LCI power steps won't shut off
Several weeks ago, the power steps on our Motorhome (2012 FR Georgetown) started going crazy.  Any time they retract or extend, the motor will not shut off until I grab the steps, and pull on them fairly hard.  Steps will go out all the way, and motor keeps on running, steps shake/jerk as motor tries to keep extending them.  Same thing happens when they roll in.  Only way to stop it is to firmly grab the steps and pull out, or push in on them (or disconnect power to the steps).
I replace the motor a few years ago when it quit, so don't think thats it. Replaced the control module last week thinking that was it. No difference. Then thought it was maybe a bad ground connection, so I ran a wire straight from the negative side of battery connected directly to the two ground wires coming from the module. No difference.
Have concluded that this probaly is not an electrical issue. It seems more of a physical problem with the steps - Motor is not encountering enough 'resistance' at end of travel, for it to shut off as it is supposed to.
Have noticed there are cam stops on each side of the steps, that steps are supposed to come up against and stop on. Found where there is a procedure in the manual to re-align them. Seems they may be out of alignment, and one side is hitting first, causing this issue where steps keep trying to move on the side where it hasn't hit the cam stop yet. Will probably try next to adjust these cam stops.
Any thoughts, suggestions from anyone that might have experienced something similar with power steps? Has anyone ever adjusted those cam stops? Or maybe had similar issues with the steps, and fixed it another way?
