sflabrkr wrote:
Mr.Mark wrote:
For what it's worth, we have averaged about 7.2 mpg's with our 42 ft. tag-axle coach at 40,039 lbs with almost 70,000 miles on the odometer. A tag axle does weigh more but it also offers more stability and a larger cargo carrying capacity.
Since you will be full timing, you will be carrying more than a part-time RV family. Your whole life will be in that coach so go as big as you can afford and with the most slide-outs. Also, a tag will give you an extra set of tires of you need to rotate to the front.
Once, we received a bad alignment (about 5 yrs. ago) and I didn't notice it until about 2,000 miles later. The inside of both front tires were wearing faster than the rest of the tire. So, I got an excellent alignment at TAFA in Nashville and rotated the tag tires to the front to have a fresh set with very little wear.
Last year, I bought a whole new set of new tires and went through the Michelin FMCA program for extra savings.
Good luck and let us know what you find.
MM.
Thanks for the info.
let me ask you this question?
You got 7.2 MPG with the tag do you think you would get around the same with 1 axle? 20% worse......?
We are currently traveling in the motorhome. I rechecked the Aladdin computer and my average is 7.8 over 68,700 miles. I have also every receipt for every tank of fuel with my miles written down (also aqua-hot usage) so one day I will figure it manually.
I honestly don't think the extra axle will reduce the fuel mileage much. The greatest advantage is the extra cargo carrying capacity and stability that it gives you. On a 42 ft. motorhome, it will take up some storage space.
If you are looking at a 41 ft. motorhome without a tag axle, check the cargo carrying capacity. You might be limited to just a few thousand pounds, whereas, we have at least 8,000 lbs. of wiggle room and can tow 10,000 lbs.
Good Luck.
MM.
