n4hwl
Oct 14, 2013Explorer
need help with left rear tail light
I have a 2004 Phaeton made by Tiffin. My left rear turn signal light is not working. I assumed that the bulb was burnt out. I checked it and the turn signal bulb is fine. I checked and found there is no 12 volt getting to the turn signal fixture when the left signal is activated. Ok Where so I go from here? I thought there was probably a connector that had come loose. I am yet to find a loose connector. Is there a fuse that controls only the left turn signal? The right turn signal is working fine. Any suggestion would be appreciated.
Ken
Ken
