427435
May 28, 2015Explorer
Onan 5000 won't start
It doesn't have any spark. Any thoughts or suggestions? Started fine about 6 weeks ago. Looks like it will be fun to get it out far enough to work on.
ksg5000 wrote:
To my knowledge Generators are installed with fuel lines positioned so they can't drain the main RV tank dry - no sensors involved.
427435 wrote:
My tank is full-----how would the genset know the the level of the MH tank? I figured it would just stop running when the genset's gas pickup stops supplying fuel.
Vulcan Rider wrote:JumboJet wrote:
My generator ran fine last October. When I went to start it in March, it would not run. I disconnected the Oil Pressure safety switch and it fired right up. I replaced the switch and it has run fine since then. May be your issue also.
In addition to that, somewhere there is a "sensor" that tells it the main tank is getting too low. It is possible that has malfunctioned also.
darsben wrote:427435 wrote:
Thanks for the replies and for the link to the manual. I hope it's the oil pressure sensor. In any event, I will post back with the resolution when I get time to work on it. Right now garden and yard work are taking precedence.
If you changed the oil that could be the problem. Onan had a problem with some 5000 generators that foaming when the engine was filled to the correct level caused the low oil level switch to open. Their cure was a different dipstick (small) that had markings at a lower level.Mine is one of them
