murphys_law's avatar
murphys_law
Proper Hydraulic Fluid to use?
Hello Everyone,
I'm still a newbie and I have a question as to what is the best hydraulic fluid to use for my rig. We have a Class A 2007 Winnebago 33 ft Voyage. The leveling system is Level Best made by Kwikee. I have read not to use Dextron 111. I have the rear passenger jack that is leaking, I've checked the hoses,and they are good,so it must be a seal gone bad. (?) I purchased Lucas Hydraulic Oil Booster and stop leak. It's as think as jelly, so I don't want to use it.
Also, I thought about replacing all 4 seals on the jacks, but I was told from Winnebago Parts that I need to purchase new jacks, etc at $800.00 each.... I'm sure there is an aftermarket seal kit that I can get, but I have no idea where to begin to search. I greatly appreciate any an all advise as to the best hydraulic fluid for my unit and any aftermarket seal kits to use.
Thank You !!
  • WHERE did you read not to use Dextron 3. Motorhome Hydraulic Jack/slide systems ALL use Dextron 3. From the Kwikee owners manual. Doug
    1. Be sure the leveling jacks are in the retracted position. Remove the breather cap
    on the reservoir and check the fluid level in the reservoir. The fluid level should be
    approximately 1" below the top of the reservoir. This standard provides an adequate
    amount of fluid for the levelers to operate efficiently. If the fluid is below this level, add a
    sufficient amount to bring the level up to the operating standard. When filling the
    reservoir, use transmission fluid only. We recommend Dextron III. Do not mix fluids.
  • Stop thinking of this as an RV item that needs repaired. The cylinder is no different that that is used on a backhoe, front end loader, dozers and such. Getting it repaired shouldn't be a problem. Just keep in mind that shop service might cost around $100 an hour so there is a point when replacement is a more economical option but you won't know unless you try.
    When I had an internal leak by, jack would extend and retract but would not lift the coach, I open a Google Map of my area (southeaster Virginia) and search for "hydraulic cylinder repair". Returned a dozen of possible sources to investigate within a 45 minute drive.
    I removed the jack, four bolts and two hydraulic lines, drove down to the closest shop. They said no problem, shop service is $X per hour and shouldn't be more than 2 hours with $X for material. A few days later they call as the jack was ready. Reinstalled and cycled the jacks for full retract to full extent a few times to bleed any air and all was good.
  • Hydraulics are used in many industries. Search for shop that specializes in that equipment. You might need to remove/replace it yourself, or hire somebody else to do it.
  • Farm equipment repair, ask around the local co-op
    I wish I had one close by, I could get my powergear curbside rear jack repaired
  • Yeah, don't use the stop leak fluid.
    Try to find a repair shop that does automotive hydraulic lift repairs.
    They can take you jack and find a seal that works.
