bullydogs1's avatar
bullydogs1
SHAME on you Monaco, Navistar, AVS or whatever....near fire
Vent mode on..Rant mode on..
Through just accident, I found out that the IOTA 50R transfer switch used in my coach was recalled by Navistar, and many other coach manufacturers as loads made the contacts burn and possible fire could occur..Someone with a Fifth Wheel posted his burnt in a fire and I looked and sure enough..pulled the cover and saw burn marks on the bus...yep...accident waiting to happen..this thing almost went up in flames and it sits in the driver electrical bay...we could have went up and probably not far from it...I called Monaco support...the gentleman said YOU ARE ON YOUR OWN, Navistar bears no responsibility for pre Navistar RV...however, in my opinion, Navistar should have either A> TOLD ME ABOUT IT....B> Do the right thing and replace it
I sure have given them business from getting some parts for my coach plus you have all records from it...
When ASV took over , they should have at least notified me, the original owner....of an issue.....
Replacing switch now after it failed....
I should consider another Monaco coach?????.Sorry Mike Snell.your company's desire to put a small amount of dollars ahead of my life, behind a legal shield..not doing what is ethically and morally right, is costing you my future business....
CHECK YOUR TRANSFER SWITCH for IOTA 50R
To the person who posted about this...THANK YOU...
  • I have called IOTA...at first, they disavowed anything because they went through a legal acquisition...Now I am being told to send pictures...And by the way, the screws were torqued properly last summer so this is a new thing...several of the connections on the bus are charred...but one of them is pitch black...and the bus there is loose itself..the wire was torqued properly...I'm just glad this thing failed now rather than on the road and a possible fire occur...My friend's FR Charleston burnt in the middle of the night at a rally...his switch was under the bed and they caught it..
  • Actually, I would think that your gripe would be with http://www.iotaengineering.com/. They manufactured, marketed, and warrantied the transfer switch in question. More importantly, I think this is actually a maintenance issue. You should not have a problem if you check the torque of the electrical terminals of the Iota transfer switch. They must be at least 45 inch pounds to avoid a condition of over heating. Note that I said inch pounds, not foot pounds. All electrical connections must be properly torqued, and do come loose over time, especially in a moving motorhome!
    You will find the Iota transfer switch on many other brands of RVs.
