want-a-be's avatar
want-a-be
Splendide Ariston Washing Machine Model ARWXF129W
I forgot to open the gray tank valve, the tank filled up and the washing machine pump water everywhere!
After clean up the washer goes thru a couple of cycles and then we get a code F11.
Code F11 says, not hot fill. ( hot water ok). Ambient temp. Is likely below freezing (it's 70 degrees here) Make sure water valves are on (they are on ) Check kinks in hose (no kinks). Tried different wash cycles and temps. Also put drain hose in a bucket and the pump works, check filter clean out, It's ok and the pump impeller is clean and turns!
All comment greatly appreciated!
