MEXICOWANDERER's avatar
May 29, 2017
Dead NOOK.
Hee hee. I thought I was fair at soldering but when the umbilical port socket broke away from the board. Not pin head size pads - pin point. Wave soldered at the factory.
I have 90% remaining battery the unit is shut off.
Have any of you been inside a NOOK Glo Light? The charging voltage is 5.0 and I suspect the Li-On battery to be 3.7
Meaning a charge regulator is in the circuit. Before I cut it's ---- off I would like to save time and ask. The battery is as old as the device - around 2 years. I am going to TRY at the utter end of things to open the unit and connect a pair of 24 gauge wires to the mini port to regulator circuit. If I can do this, I will recharge the battery manually using my lab power supply.
Second if. If I like what I discover (easy access to the circuit, when I get a replacement NOOK I am going to rob the battery out of this one and piggyback it onto the reverse side of the new reader then slip the whole enchilada into a "Nook Case". When I detect a noticable loss of capacity with the new reader I'll snip the parallel wires and go single battery.
The NOOK I have now has decomposed its way to a pile of electronic snot. Gorilla tape, missing button, you name it. So the original NOOK is worth two tenths of a cent.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 28, 2026
