mrekim wrote:
JBarca wrote:
Also in case you did not know, on 1,200# and heavier TW's, is is best to bolt on the snap up brackets as the C clamp snap up setup has been known to spring open in turns.
I have the heavy duty ones, but they do have a hole for a carriage bolt in them. How do they spring open? Do they actually bend and pop off the frame?
I found some pics on the snap-up and and failures
The bolt on by Turk2500
Truk2500 bolt on snap ups on tube frameSnap up failure
Snap up failureI see you found pics of Fisherguy's welded nut plates. Good.
There are others pics on the forum, I found those quick. The top springs open. How far it opens depends on the loaded TW, the WD bar size, the angle of the turn. It "depends" on if it will fall off. If you catch it the minute it bends, odds are lower. If you find is a few hours later, the flopping around may allow it to come off.
You mentioned the cap on the end of the tube frame, it may be there more to keep water out and rusting the tube than structural. I have seen them both ways.
The riv nut that is pressed in from the outside behind the frame bracket, I myself have not used them, in steel anyway. I do not see any slits in the riv nut to see if they expand out like an expanding anchor. They "look" more of what looks like a serrated tooth swedge fit to help stop anti-rotation. They seem to be able to take 75 ft lb but do not know who well that are from pull/strip out.
You will have to make the judgment call on this one. I'm over cautious on hitch work and would go a bolted solution. If you have access to a 1/2-13 tap, here is an option.
- Align DC frame plate and hold with set screw from behind.
- Ideally using a 1/2” transfer punch, prick punch the frame plate favoring the top of the large hole in the DC frame plate. Want to stay out of the frame radius if you can.
- Using 27/64 tap drill, drill through both sides of the tube.
- Using 1/2" drill, drill outside hole to center. Do not go all the way through.
- Tap inside hole 1/2-13
- Create a 3/16 or 1/4" thick backer plate with clearance holes to span the 2 inside taped bolt holes.
- Screw in long enough grade 5 or 8 hex bolts. Gently tighten and watch the inside frame to not crush the tube.
- Install backer plate.
- Install nuts and lock washers on bolts and hold bolt head while locking the nut against the backer plate.
In your case you will have to start by using the self tapping screw holes already in place. This method will work without the tapped hole, however the tap helps create a thread lock with the nut and not crush the tube. If you are really into it, tap the plate just use like 3/8 or 1/2” for the tap plate.
Let us know how this comes out.
John
