mrekim wrote:
I'm still nose up with the hitch shank flipped up and the shorter ball. I measured at different places in the parking lot and got between 5/8 and 1 5/8 from front to rear. These ranges were obtained by measuring at a few different locations in the parking lot. If I had to pick one location that seemed most optimal the reading was 1 3/16 nose up.
snip...
I'd like to better understand the purpose of perfectly level to nose down on the trailer. Is it all about tongue weight?
snip...
Also these measurements are over a distance of at least 25 feet. So, we have sin-1 (1.1875"/300") = .0006 degrees. If my math is right and we consider degrees vs inches then it seems pretty level.
Hi Mrekim,
I have been out camping and just saw your update. Since you are working hard at optimizing your setup, I'll point out one area you may have taken a step backwards on.
When Barney suggested this he may have not realized this and you may have forgot what learned working through this. Sorry I did not explain this more in the beginning.
Using the hi rise tow ball on a 6" A frame with the DC helps optimize 2 areas.
1. The ability to gain more clearance in the DC area so the WD bar does not interfere with the DC arm during compound angle turn.
2. The ability to lower the hitch head on the 6" A frame with the ball coupler on top to help avoid a crash of the trunnion bar lug into the frame during hard angle turn.
I suspect no 2 is going to not get you since you are back on the standard height ball. Since you are on the new 1 piece head, it may help but may not cure. Point: check it out.
See this pic of my older camper on a 5" A frame, ball coupler on top and the 3 piece Reese head. The trunnion lug will hit the frame as the head it higher up. Being on a 6" frame is even 1" worse
Now lets look at your pics in the start of this process. Note: you are on 7 links in this mock up and you hit the trunnion lug into the frame, but 3 piece head
Right now by the last set of pics you showed up you where on 6 links under tension. And this is good. But you were on the hi rise ball too. This setup is about perfect from the hitch head trunnion lug and DC perspective. However you have a nose high issue to deal with.
A heads up, odds are high going back to the standard ball, while you might have DC clearance on 6 links with the new all cast head, you may have sacrificed getting a trunnion lug hit on the frame in the advance stages of a turn on a compound angle. I would check to see it that is occurring. You helped the ball nut hit going to the new head, just you may have forgot about the cast lug hit on the standard ball.
Here is a thought that I would investigate. Go back to the 1" hi rise ball on the new head and run at 6 links under tension. This creates all the needed clearance both at the DC area and the trunnion lug and frame area. Now you need to deal with the high trailer nose problem.
I have found the standard Reese shank, the one you have, works well in several setups but it does not work well when you need a drop shank which is what you need to lower the trailer nose down. The standard shank does not have much drop. 1 1/4" from the top of the shank on a trunnion bar setup. And when you flip it up there is sort of a no mans land of adjustment in the exact middle area you are at.
Consider exchanging your present shank for a true 6" drop shank or 4 to 5" drop as declared by Reese. Note: this does not mean the shank is 6" long, it means it will drop a HP trunnion bar hitch head 6" from the standard "0" location. The shank itself is actually 12" long from the top on a 6" drop shank. According to the 2013 Reese catalog they do not offer a 4" drop. It is the standard shank at 1 1/4" which you have or a 5 3/4" drop. See D-19
http://www.reeseprod.com/content/downloads/catalogs/Cequent_2013_06_Weight_Distribution.pdfNote: The drop is rated different for a round bar or trunnion bar head. You want trunnion bar head
This is the "ideal" Reese shank if you can still find it. There are plenty of fine adjustment holes to help get better resolution in dropping the TT nose down. There may be some still left in dealers stock, if not then you will have to use the newer ones.
Here is a true 6" drop shank next to the standard shank you have. Yes I have both...
Looking at your pics, I see what I think is the bumper and the rear swinging doors of an Excursion. Am I right? I have helped a few buddies with their Ex's and know some of their traits.
Look here when I had by K2500 Suburban on my present TT. 6" A frame, ball coupler on top, 3 piece trunnion bar head, pre 2010 redesign HP DC with hi rise tow ball. That is a 1,200# loaded camper tongue weight using 1,200# WD bars correcting a 130" Wheel base Burb back to unhitched front end ride height. The ball height on this camper was 24" at the time.
Ideally in this case I needed a 4" drop but I had the 6" drop already and was changing TV's soon so I used what I had. If I was to keep this set a long time, I may have cut the excess below the weld off if I had length issues.
Your camper is empty I "think" right now, is this correct? The EX with family on broad is only going to handle a 1,200# TW and stay within the rear axle door sticker rating. As you load the camper you will need more head tilt to shift weight off the rear axle and some to the front EX axle and the TT axles.
When they say level is best, and it is, the TT axles are loaded as equal as they can be. And the air currents hitting the top of the TT do not create other handling concerns.
When you are nose high by a lot, and I consider 1" plus a lot, in some TT's this can cause instability in towing by the way the air current hit the top of the camper. When you are in the slight nose down position the air hits the of the camper different not causing negative handling characteristics.
For the 1st time I have finally seen TV manufactures now recommending in their manuals that level is best and next is nose down. Many of us have know this a long time but now it is starting to come into print.
As far as TW and nose high and nose low, it all depends on the center of gravity the way the camper is built. On my camper when fully loaded I raise the nose or drop it by 3" and only change the TW by 50#. Others have reported they dropped the tongue 1" can gain 100#. Others raised it 1" and gain the 100#. All campers are not built the same. So "it depends" on if "your" camper will gain or loose or nothing at all with nose low of high.
In summary, my thoughts for all conditions are, go back to the 1" hi rise ball, 6 links under load, stick with the new cast head and shim, tilt the head as needed for WD, 1st load the camper and the truck like you are going camping. Then adjust the WD, (with the DC in place) to return the front end of the TV very close to unhitched weight/height. When done, get the correct drop shank to level out the camper for towing. While you can only be accurate within 1 shank hole, choosing between being 1/2" high to 1/2" low, pick low. Being 3/4" high to 1/4" low, pick low. Being 1/4" high to 3/4" low pick hi. Being 1 1/4" plus or greater lower starts raising the concerns front TT axle bearing more weight than it should be for the long haul.
Hope this helps
John
