mrekim wrote:
I made a video of the snap up and the spring bar on one side. It's pretty boring, but it does show that's there's some motion in the snap up. It was surprising to me how often the little keeper pin is holding some amount of weight. I assume that when "popped out" the keeper is bearing a non-trivial (or certainly non-zero!) load.
http://www.youtube.com/watch?v=hg8XwpmSy_w
I'm not sure if this help at all with the Dual Cam issue. I guess it does if whatever force is causing the arm to want to go "out" still exists with the Dual Cam setup.
Actually it does help, or at least helps me realize a few things to add to this topic. I did some digging into your setup with no DC installed.
Lets look at your video pics with no DC, but a level of WD.
Here is where the toggle is locked in towards the camper
And here is when it is popped out
When I first saw that pop out, with your TW of 1,100# it did not add up with the heavy load of WD as to how the WD bar could undo the toggle just making a turn. The WD bar pivots in the hitch head, The chain is under heavy force, well normally it is, there should not be that much side thrust. So I started doing some investigating.
My belief is when you are running 9 links and did not adjust the hitch head angle from where you were with the DC, you have reduced the WD force load by a fair amount. With that much reduced chain force, the bar swing will undo the toggle.
I went to my DC chain plate and chain to do some measurements. I wanted to back into what is the chain WD force with the chain plate using 6 links under load and then what is chain WD force with the chain U bolted to the WD bar and no DC? That is a good question.
Since I have a "collection" of Reese hitch parts (I'm a good customer) I realized a few things. Your hitch only has 9 chain links, h'mm, my original one has 11 links and looks thicker chain. Measuring the old and new hitch parts, here is what I found.
My 2003 bought HP DC chain has 11 links, a cross sectional link thickness of 0.330" dia. and a chain link pitch of 1.355". (On my current camper)
My 2007 bought HP DC chain has 9 links, a cross sectional link thickness of 0.300" and a chain link pitch of 1.380" (now on my flat deck equipment trailer) This one appears to match what you have.
It appears Reese changed the chain over the years somewhere between year 2003 and 2007. Have no idea why. Cost reduction??? See here:
My 2003 DC chain. 11 links as I run on 7 links under tension
My 2007 bought HP DC chain with 9 links. I bought this in late 2007 when we bought the current camper. When I sold my prior camper I put a new DC on it for the new owner as I kept my original DC for my current camper. On this smaller low riding camper I ran 5 links under tension as the I only had 6" of DC ground clearance.
And now your 2013 DC setup
I still have the 2007 chains from the DC kit. The new owner of my old camper had a Reese HP hitch, just no DC so I put his chains on that new DC. I use the 2007 chains now on my flat deck trailer along with my older 1,200# WD bars as a stand alone WD hitch. Basically your setup when you went for a ride in that video.
I want to stab at determining the WD force on your rig with the DC on 6 chain links and then running 9 links and no DC. When you took off your DC and put the chains on the WD bars, I "assuming" you did not change the hitch head angle. Please confirm, yes/no?
Measuring my DC chain plate and 2" diameter DC lobe, the 2007 vintage DC chain like yours, I come up with 3.84" in the length the DC chain plate needs to connect to the cam arm verses hooking the chain to the U bolt on the ends of the WD bar.
When you removed the chain plate and went from 6 links to 9 links under tension you reduced the WD by a fair amount. 3 chain links with a pitch of 1.380" is 4.140". Subtracting the DC chain plate of 3.84", you are 0.30" longer on chain under load. OR 0.300" less preload on the WD bar. This is were the less WD came from.
(Edited 11-25-13 to correct chain plate to 3.84 in place of 3)
Be back later after I get some more WD bar displacement distances when the hitch goes through a turn with and without the DC installed. We can then start putting estimates on the chain forces.
John
