Tacswa3's avatar
Tacswa3
Rookie Mistake
Today I'm going through an all systems check on my new TT. Hooked up water, made sure plumbing worked, hot water heater, etc.
I put some water in the fresh tank (found a leak at the drain valve area, appears to be hairline crack on the tank) Anyway, ran the water pump all was fine.
Here is where I messed up. I drained the fresh water and left the water pump switch on by accident. Realized I left it on 6-7 hours later. I heard it humming and said ****!
Here is what confuses me.... Why would the pump hum when there was no call for water? It didn't have the loud pulsating chatter when it pumps, just a quiet purr. During my testing, turn on faucet and pumped activated. Shut off faucet and pump went quiet. I don't know why it was humming when there was no call for water. I put water in the tank and tested it again and it worked.
How much damage do you guys think I did to pump?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
