robsouth's avatar
robsouth
Explorer II
Jun 28, 2013
Dertermine Rear End Gear Ratio
Is there a way to determine what rear end gear ratio (4.10, 3.73, 3.55) etc is actually in your truck. Sticker on glove box says 3.55 but I have reason to believe that the gears may have been changed by a previous owner. Any way to tell for sure?
  • Tape a length of string to the side of the driveshaft. Mark a wheel and drive one revolution forward. You should be able to tell within a quarter of a turn how much the string has wrapped around the driveshaft.
  • You should mark the drive shaft and BOTH tires. Turn BOTH rear tires one revolution and count the drive shaft turns. If the drive shaft turns slightly more than three and a half times the ratio is 3.55-1.
    Jim
  • With only 1 wheel off the ground, count the turns of the drive shaft to 1 turn of the wheel, and double that.
    If the driveline turned 2 times, the ratio will be 4 to 1
  • 1. Chock the wheels.
    2. Engine OFF, transmission in neutral.
    3. Put a piece of white tape on the drive shaft.
    4. Another piece of white tape on one of the drive wheels.
    5. Jack up the wheel with the tape.
    6. While counting the turns of the drive shaft, turn the wheel 10 turns.
    7. The number of turns of the drive shaft will be 10 times the gear ratio.
    Easy as 3.14159265
  • there's always the fool-proof way of marking the driveline and counting the revolutions while the wheel turns one time.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
