alank2's avatar
alank2
Generator question - let carb run dry or keep it wet?
I was helping my father in law get his genset running yesterday and ran into the same issue we ran into about 6 months ago. It wouldn't start, was difficult to pull the cord. It would finally start up and then stop shortly thereafter and gas would burst out of the air filter box. Checking the oil area reveals that it is full of fuel! Dump the fuel and put oil back in and it will start back up and run.
Doing some reading and talking to my dad, the thinking was that something in the carb is stuck allowing fuel to slowly work its way into the engine because we are leaving the fuel switch on.
I've done this for probably 8 years with my Yamaha 3000 and had no ill effect, but am a bit concerned that perhaps that isn't the best practice. I double treat my fuel with stabil the first day I get it and it is pure gas (no ethanol).
So my question is - should the carb be left wet with treated fuel, or should I shut off the fuel switch and let it run dry. I've always thought letting it run dry might leave a little residual fuel in there that could dry up, gum up, varnish, etc.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
