ledcomp's avatar
ledcomp
LED Dimmer
I wanted to stabilize my LED lighting circuit voltage using a buck/boost converter. When the LED's are dimmed you can see alot of fluctuation from battery voltage change like when the water pump cycles. My concern is with the PWM LED dimmer being driven by the back/boost converter. I'm trying to not let the magic blue smoke out of my PWM dimmers.
If this will work, does anyone know of a 5 amp+ buck/boost that will work with a common ground?
Thanks
Dave
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
