tinstartrvlr's avatar
tinstartrvlr
Question about replacing fridge
Greetings all,
I tried a search for this answer but had no luck.
I have reached the end of my patience with the Dometic fridge I have and the problem that seems to be unfixable.
I have found a mid size residential fridge that will fit in the space with some slight modification.
It's in a slide, so I have the two vents that I will need to do something about once the residential goes in.
Those of you who have replaced your fridge with a residential, in a slideout, what did you do to seal the vent holes? Or do they even need to be sealed up?
Any guidance would be greatly appreciated.
