bearsnob's avatar
bearsnob
Slide alignment problem after awning hangs
The slide awning was getting tattered and I should have removed it. But it was still helping some. Went to put the slide out and it got hung up somehow. Had to go cut it off to get the slide out. There was a loud noise when the awning hung up. Not sure where but probably in the slide mechanism. The slide then went all the way out on the hydraulic side but sits about three inches in from the wall on the other side. Been trying to diagnose it and getting nowhere. An rv tech told me today that in cases like these they sometimes jump the track. That would makes sense. No pins have been sheered and the slide moves in and out like always. I cannot find any obvious slippage on the adjustments. The gears look good to me and lubrication made them work better like before. This is lippert rack and pinion on a dining room slide that's supposed to sit flush with the floor. Now it does on one side and not the other. Concerned that I need to fix this soon before it causes another problem. Any thoughts?
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
