BFL13's avatar
BFL13
Explorer II
Jul 27, 2017
Solar- Series for Higher Voltage vs Parallel Lower Voltage
I keep reading how you do better with the higher voltage in series unless there is shading.
With no shading I have switched my three 100w panels back and forth several times (in bulk MPPT that is 51 vs 17 volts for me), and cannot get any better amps to the battery either way.
I even did the "low light" test with overcast grey sky so I was only getting about 2.5 amps at noon, and still got no difference.
It was not low light enough so I could see whether you do keep getting at least some amps with the high voltage and none when in parallel as in the "story". It would be lower amps than the 2.5 I got in better light obviously, even it if were true (which I doubt), but then who cares if you are getting 1 amp instead of none? In four hours that would get you a whole 4 AH. Gosh! :)
Anyway, I just couldn't make it happen no matter how many times I tried it.
I did have a thought that the MPPT controller efficiency might counter any good effect from the higher voltage. The buck converter is less efficient going to a 13v battery from 51 volts than it is with less of a drop from 17v.
You still get the wiring advantage of a higher panel to controller voltage by being able to use thinner wire, but that does not help me with my already fat wire in that path.
I just can't see the point except for the wiring thing. If your wires are fat enough, why not just leave the panels in parallel in case there is some shading, since you (at least I ) get the same amps either way, even in "low light" ?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
