eastbay's avatar
eastbay
Solenoid as relay question- install inverter
Hello All- 1st time post!
I'm attempting to wire an inverter into my coach outlets on my 1999 Born Free 24RB.
What I'm trying to do is install the inverter on a transfer switch to the outlets circuit only, as I will not be powering the microwave or A/C from the inverter.
This has all gotten a bit more complicated than perhaps it needs to be and I may be posting more about it later, but for this specific question-
I'd like to mount the inverter in a cabinet and don't want to ahve to use the power button on the inverter to turn it on and off. Since I had a hard time finding a 12v switch rated to 100 amps (1200 watts @ 12vdc) I had the idea to install a solenoid on the power line and switch that.
It seems like it will work but now I'm worried that if I leave it on overnight the solenoid itself will draw power to remain "closed".
This will be an issue since I usually leave my cell phone and laptop on charge overnight- if the solenoid is drawing much power it will be a long time drag on the battery for little benefit.
Maybe I should try hard to find a mount for the inverter where I can reach its power button easily.
Any advice appreciated!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
