BFL13
Dec 04, 2015Explorer II
The Big and Small Inverter Scam UPDATE-Tested.
Updated 7 Dec--
Not that this is picking a fight or anything :)
I went with the story that you should have a big inverter for the big things and a small inverter for the small things for a few years, but then decided it was a scam. Now just have a big inverter for everything. That's after some "quality time" with my Trimetric over the years.
For example, you can run the TV/DVD on a 300w or 3000w inverter, but you can't make popcorn for the movie with the 300w job.
The Xantrex-made 3000w MSW inverter now fitted, pulls 0.5 amp in standby ( which is peanuts to me, but never mind that).
I don't know how much more it pulls in amps to run a TV/DVD than a 300w inverter would, but let's say it is twice as much. Might even be the same as that 0.5 although that is bogus, since it is now a question of inverter efficiency curves when under load that counts which has nothing to do with their respective stand-by draws. Anyway let's go with 0.5 vs 0.25 to get started.
So there you are after supper with DW watching a movie (10 amps say) and the furnace is on (7 amps say) and one light on (3 amps say)
So there you are with 20 amps draw for a two- hour movie, never mind the furnace going on and off)
So the difference is 20.5a vs 20.25a for two hours, or 41 AH vs 40.5 AH in the same time with the small inverter. This is a joke, right?
Ok so after the movie, you turn off the inverter with its remote on/off switch so now there is no inverter draw at all, no matter how big or small the inverter is.
Which is why after smartening up :) I no longer have two inverters, just one big one that does everything from charging phones to running a MW.
