beemerphile1's avatar
beemerphile1
VEC1093DBD replacement fan?
My Black and Decker VEC1093DBD charger fan acted up last winter. In below freezing temperatures the fan squeals and takes a while to start running. In warm weather it works fine.
I want to replace the fan before this winter. I took the original out and found it is a 60mm x 20mm fan. Does anyone have recommendations for a replacement?
I have read that the original has sleeve bearings but haven't been able to verify. I also don't know the CFM of the original. I would like to have equal to or more CFM in a ball bearing fan.
I found this one as a candidate;
Amazon 60mm X 20mm fan $8.33
The original is two wire and this replacement is three wire but it shouldn't matter.
I have read that some used an external fan but I would prefer to stay inside the case. An external fan would be complicated because the air intake and exit are in close proximity on the same side.
Recommendations?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
