mr70ss's avatar
mr70ss
2500HD and a 4000lb camper...
Ok so I've been digging around on the forums for answers, and now it's time to get a consensus on what I have come up with...
truck specs and weights
09 2500HD Z71 CC LB 6.0 gasser
285/65/18 toyo at2 (3640@80psi max)
Dick Cepek 18x9 wheels (3640lbs max)
Torklift frame mounts
Torklift stable loads
Firestone airbags
Super springs SSA15 (5000lbs)
Weighted the truck with a full tank and me and the wife, here are the #'s
front axle 4040lbs
rear axle 3080lbs
total 7120lbs
camper specs
adventurer 910fbs
3284lbs dry (inc. options)
4228lbs wet (inc. 50g water, 40lb pro., batteries & 300lbs misc)
47" COG
so I found a great little camper weight site http://www.visualsc.com/tc_calc.htm
I put all the numbers into the calculator and here is what I get back..
rear axle 7077lbs
rear tire 3538lbs
front axle 4271lbs
front tire 2135lbs
gvwr 11348lbs
Now I do know that in this model when you add the water weight, it will move the COG forward.
from all the searching I've done the only differences from a 2500 to a 3500 is the spring pack (extra overload leaf) and wheels and tires, 16" to 18".
My question is am I wrong in figuring my rear axle is now 7280lbs (both wheels and tires are 3640lbs max X 2)? I know i'm way over on that the door tag shows for gvwr & gawr, but I assume those numbers are for a factory stock setup.
