SidecarFlip
May 08, 2017Explorer III
Ammonia versus Compressor Fridge...
After all the talk about Danfoss compressor fridges and how much better they were than the old school Ammonia Units, I decided to 'fiddle with mine and do a long term test using a remote digital recording thermometer.
First thng I did was open up the rear cavity. My fridge is a side vent, that is, not through the roof, intake low (with plumbing and control board) and the upper vent vertical on the side of the camper at the height of the top of the fridge.
I opened it up and removed the one small 12 volt muffin fan Suburban had installed. It was a cheapo sleeve bearing fan, very noisy. I replaced it with 2 Fluid Dynamic Bearing 120 MMM high flow computer fans (23 bucks, E-bay. Had to make up a set of brackets as I wanted the fans as close to the upper condenser as possible. Suburban has already installed a snap action thermostat (on at 90 off at 70) so I wired both into the existing thermostat.
I also added a lot of R13 unfaced insulation between the fridge and the cabinet. I actually stuffed almost 1/2 roll in. Plenty now.
I also fabricated an upper baffle that fits tight against the back of the upper condenser and screws into the camper side,inside, effectively channeling the air flow with no turbulence as it passes through the condenser.
I took a full 20 pound bottle of propane (valved off my second bottle) and set the fridge on gas only (it is shore powered sitting in the yard.)
So far, it's been running for 3 weeks straight on that bottle, I'm expecting over a month. Amp draw with the fans running is 1.8 amps, with the fans off. .2 amps..Temperature swings (day and night) (and the camper gets the afternoon sun on the fridge side) is 4 degrees.
Last year I had to run the fridge on setting 5 to maintain 40 in the compartment. It't drifting between 33 and 36 inside now..... on setting 2...
I measured the cool down time from ambient as well. It took exactly 3 hours from ambient to 33 degrees.
Still chugging along out there as I post this. When it runs out of propane, I'll post it.
If it ever dies, I'll install a Danfoss unit but for now the old school fridge appears to be doing well.
