biggjb's avatar
biggjb
Converter will not charge batteries
Hello, I need some advice. I purchased an old TC and on my first trip I realised the batteries were not charging when hooked up to shore power. My previous TC's converter always hummed when it was plugged to shore power, however, this one did not. I checked the connections at the converter and found the converter output was zero. I then replaced it with a Progressive Dynamic 35Amp converter. Once plugged into shore power I saw all the light blinking and check the battery connection to the converter and it showed the voltage from the battery. I then checked the output of converter and it showed 14.4 volts. Good I thought. Then after my next trip I realised again the converter was not charging the batteries. I checked on this blog and someone suggested there must be a blown fuse between the batteries and the converter. I then found the fuse and it appeared good. No change though, the converter still will not charge the batteries. I then did the following. With the battery disconnect the 12volt system doesn'twork. I used my voltmeter and checked the connectivity across the neg and positive of the battery connection on the converter and the resistance is zero. I also checked across the neg and positive of the converter and it too has a resistance of zero. I am no electrician but the resistance across the Positive and Negative terminal on the battery side of the converter and between the Positive and Negative side of the converter should not be zero but should be 1. I am at a loss as to what the problem is...any suggestions?
  • It seems that you have the converter output going directly to the battery and the from the battery to the fuse block . When you disconnect the battery it in turn disconnects th converter from your 12v system . It should be converter to fuse block then fuse block to battery . That way you have power from either converts or battery . The converter you have will power 12v system with or without battery . A fuse can look good and still not be , try another fuse .
  • wnjj's avatar
    wnjj
    Explorer II
    If the converter is putting out 14V when powered up, it’s fine. If there isn’t the same voltage (or nearly so) at the battery you still have an open circuit between the two.
    Posted at the same time as “time”. ;)
  • If the converter is producing 13.2+ volts and the battery is a bit lower.... you have an open circuit. Use that voltmeter and check voltage along the path to the battery. At some point you will drop from converter voltage to battery voltage. Need to repair, replace, adjust, clean, or tighten that point where the voltage changes.
  • You need to investigate the systems.
    Older converters were giving 12 AC current for the camper and only radio + charging had small separate circuit of DC.
    Newer converters give 12 DC and often works parallel with batteries, so my first guess was that you did not connect old small cable for battery charging.
  • The problem is pretty simple; the solution might not be.
    Your batteries are NOT connected to the converter.
    OR....it might be more useful to state it the other way: Your converter output is not connected to the 12 V system in the RV, including the battery.
    While a meter is an indispensable tool, physically tracing the output wires leaving the converter might be necessary here.
    BUT....what exactly do you mean that the fuse "appeared good" ?
    You have a meter, test it.
    If it is good, you should see the converter output voltage on BOTH sides when the converter is running.
