Greene728 wrote:
I get and understand what you are saying. My post was simply let others know that 1. The parts are finally becoming available. 2. My frustration with FCA and being contacted by my service rep rather than FCA first. Maybe I worded myself wrong IDK. I have the means and skills to do the pump myself and have kept a close eye on it. I'm fortunate enough to be very near a reputable dealer who takes pretty good care of its customers and have a good relationship with them. I was good until the sarcastic comment that was unwarranted and uncalled for (Cummins12v98). I always try to be respectful on here and all other forums that I belong to and expect the same in return. If I ask for it I can take it. That wasn't the case here and its not appreciated.
BTW, I got the work completed this morning and was in and out in just over 2hrs total. And apparently, my truck isn't effected by the shift lock issue. If anyone happens to be near or passing through LaGrange GA, give Mike Patton Dodge/RAM a shout if needed. They are good folks. Not perfect mind you, but they sure beat the pants off most dealers I've dealt with.
FCA sent you a recall notice to take your truck to a dealer and have it checked, correct? It is the dealers job to check your truck to see if it is affected by the recall. If it is they order the part or parts and notify you when the they arrive not FCA! It is the dealers job to call you!
As for Cummins12v98's comment "So what should they do??? Not tell you anything then one day get a call and say go to your Dealer????
Wow what an inconvenience!". I'm not sure this comment warranted such a reaction on your part IMO.
Glad your dealer got the truck sorted out for you and hope everything is better.
Don
On Edit, you say "
Facts huh? Well why didn’t you ask for facts?
I did go to the dealer and had it confirmed. The same time I had the SCR recall done which is why the service writer called me. So did the dealer tell you about the water pump recall or FCA? Not being a dick here but you post is really confusing as to what you are up set about. This was your first post "
Finally. I got a call from my service advisor letting me know they actually have the new style pump and set me up for tomorrow. I haven’t heard anything from FCA though. I absolutely love my truck, but slightly less than thrilled with FCA and how this recall has been handled and drug out. I received my initial recall notice end of September and here it is mid March. I hope to never need them again.
. As you can see you say the dealer called you to tell you they have the new pump. If your truck was affected by the recall you should have gotten a notice from FCA to take your truck to your dealer and have it checked. If you never got a notice then FCA via your VIN knew that your truck was not affected and as such you would have not been notified of the recall! That is how it works, FCA, GM, Ford and all the rest send out recall notices only to the vehicle owners that are affected. They (usually) know when the issue first showed up and can use the build dates for sending out recalls.
