- GdetrailerExplorer III
MegaCab_PL wrote:
Not sure if the OPs v10 has the idle speed valve. My 4.6 from the same family does not IAC, all rpm control is in PCM. Clean the throttle body.
Correct.
Not ALL modular engines have IAC.
Between 2003 and 2006 on the modular engines the IAC was eliminated and the throttle body went to electronic drive by wire.
IAC AND cracked vacuum lines are chief culprit of the symptoms tho OP is experiencing for non electronic drive by wire throttle body.
For Electronic drive by wire throttle body the symptoms the OP describes is dead on with a sticky throttle body..
If OPs vehicle is 2005 or newer I would bet that the throttle body plate is gummed up. This causes the computer control to go into limp mode when it gets severe enough but until then it will stall ONLY when at a stop and shifting from drive to park or reverse to park (note that the engine RPM will often drop from 600 RPM to less than 400 RPM when stopped with this condition).
When throttle plate sticks severely enough the computer commands limp mode, turns on the WRENCH light and DISABLES all throttle pedal response.. So fix it now, before you find yourself going up a hill with a load and no throttle..
This IS a very common problem that no dealership will talk about.. They simply replace the throttle body instead of cleaning it.
In a nutshell, the PVC valve vents the oily vapors from the crankcase right below the throttle body.. Those oily vapors will build up layers of gummy sticky residue on the throttle plate and around the throat of the throttle body until the throttle plate can no longer move or return to fully closed position.
Throttle body can be cleaned without removal but you will need some help or a way to prop the gas pedal to the floor with key on..
Do a search for cleaning a modular throttle body.. You will find some step by step instructions. - GolfcartExplorerI had a very similar issue with my old 06 superduty diesel..
Ended up being my battery was loose and kept sliding over and grounding itself out on the frame of my truck.
Check the simple things, you might be lucky and its something stupid like that - shum02Explorer
majorgator wrote:
The first thing (and only thing) you should do at this point is plug it in and read the codes. It's not a guarantee to expose the problem, but 10 minutes could save you $1000 or more of throwing parts and labor at an unknown target.
Oh, and go ask this on a ford excursion forum. More specific knowledge there than on an RV forum.
x2! Several really good Ford truck forums around.
So far two pages of complete guesses. - MegaCab_PLExplorerNot sure if the OPs v10 has the idle speed valve. My 4.6 from the same family does not IAC, all rpm control is in PCM. Clean the throttle body.
- Adam_HExplorerCommon issue that could cause stalling is the PCV elbow at the back of the throttle body. Follow the line up from the valve cover and feel if the elbow is collapsed. 10 minutes to check and no scanner needed. Unless you have a "heated" pcv the part is cheap.
Adam - colliehaulerExplorer IIIIf there are vacuum hoses I would look for a cracked or disconnected hose first. Just had that problem last week with my old blazer hose, vacuum hose was split. It would die at stop lights.
- majorgatorExplorerThe first thing (and only thing) you should do at this point is plug it in and read the codes. It's not a guarantee to expose the problem, but 10 minutes could save you $1000 or more of throwing parts and labor at an unknown target.
Oh, and go ask this on a ford excursion forum. More specific knowledge there than on an RV forum. - gboppExplorer
mikebte wrote:
Carburetor shot and you need a new transmission.
Do you sell cars for a living? :B - ROBERTSUNRUSExplorer:) Hi, some Fords have a rubber flex hose between mass air flow sensor and the throttle body; This hose can crack (hard to see) and open up with engine movement. Extra air leaking in can effect how it runs at slow engine speeds. I have found and fixed a few of these.
- What about one of those multitude of safety sensors?
Specifically one that turns off the flow of fuel in the event of a crash impact. Maybe one of those is malfunctioning and now has a "hair trigger"
44,052 PostsLatest Activity: Nov 23, 2025
