RoyB
Aug 28, 2013Explorer III
POPUPs with Solar Panels added to roof
Would like to see some photos of POPUPs with SOLAR PANELs added to the roof area.
I am in the very early stage of looking into installing SOLAR PANELS on my Starcraft 14RT Off-Road POPUP roof.
My thoughts are two 120WATT size panels on each side of my roof mounted fantastic fan location running with the roof line. A third possible location is between the roof mounted air conditioner and end of the trailer roof running across the roof.
This 2008 13RT photo shows the roof mounted air conditioner and fantastic fan locations which is identical to my setup.
Mello Mike's TC solar install is my inspiration
I am not a fan of drilling holes in the top roof area and would like to engineer something like the roof mounted cargo carriers that are attached to the down sides of the roof support. Then mount the two sets of panels to that. This should give me a couple of inches between the bottom of the panels and the roof area. Of course I have my awning running down the front down side lip of my roof like shown here which may present a problem getting some brackets behind it.
Interested in how others may have installed cables from the roof area to the main body of the POPUP to allow for raising and lowering the roof. I will want my panels active charging my trailer batteries even when in tow mode
Just needing food for thought here...
Roy ken
Roy ken
