- MarslandExplorer
tomman58 wrote:
We never have used the stone. We use one of those cookie sheets with the two piece construct that has an air lock between them. Works fine the air lock prevents burning of anything in the first place. No problem in many, many years.
Quick question for the mentally challenged (me), do you use the cookie sheet as a 'buffer' by putting it on the level below the rack and then place your baking dish/pie dish/etc. on the rack? Or do you put it on the rack with the container your baking with on the cookie sheet?
Or am I over thinking this????????????????? - Bit_BucketExplorer
X2 Haven't found anything better yet, tried the stone and the pizza thingy, nothing compared to the air bake sheet for us... - PenManExplorer
x2 - 2012ColemanExplorer II
Jacksons wrote:
And does not crack
a air bake cookie sheet does the same and weighs less - MO_RookieExplorerwrap the oven rack in foil have not burned anything since
- JacksonsExplorera air bake cookie sheet does the same and weighs less
- SteamguyExplorer
- Big_LoveExplorerStone source: unglazed floor tile from Home Depot.
- JRS___BExplorerI am thinking the problem with most RV ovens is that the burners are a "U" shape. So more gas is burned and more heat is generated at the bottom of the "U".
This, or course, creates the hot spot at one end.
It is the same setup in in many outdoor grills. That is why I look for either grills with a "H" burner, or multiple straight line burners parallel to each other.
So a stone should help any gas oven with a U shaped burner.. - gon2dadawgsExplorer"Everybody must get stones" :) I'm the cook in this family and now I need to get a stone! A few cast iron pans and such....now a stone...better go to the scales someday! Any preferred stone source...link please.
Michael
