โJan-21-2015 09:37 AM
โJan-22-2015 08:40 AM
wa8yxm wrote:
I can not be sure of all models but most of the Atwoods I know of have 120vac delivered to the "Rear" (inside the motor home) of the water heater, tehre is no 120 volt at all to the outside or to the switches, they are all 12 volt.
If you access the "Rear" (where the pipes connect) you will see a box, may be black plastic, or metal, it will have 3 pair of wires going to it.
120 volt in (ROMEX)
120 volt out (To Heat element)
12 volt control
inside the box is a relay
The switches tell the control board to use Gas, or to close that relay when heat is needed.
โJan-22-2015 08:17 AM
โJan-22-2015 04:39 AM
โJan-22-2015 02:04 AM
Kenmartin1 wrote:
Atwood g10-3e no power at switch or outside at unit, but fuse is good. Does anyone know if the power goes through the switch before going to unit? Could my switch be bad? It's the type of switch with the red light that let's you know when it's lit. Thanks Ken
โJan-21-2015 07:57 PM
โJan-21-2015 07:44 PM
โJan-21-2015 02:54 PM
โJan-21-2015 02:22 PM
โJan-21-2015 01:48 PM
โJan-21-2015 10:12 AM
