LonnieMac's avatar
LonnieMac
Clearance lights continue to flash
Hi Folks,
I have a 2005 Holiday Rambler Endeavor and when I lock the door using the Keyless "Key Fob" the clearance lights flash and then continue to flash until you unlock door again?? If anyone has a solution for this it would be great appreciated??
Respectfully
Lonnie
  • Mine has only one lock that the remote activates and it is the only one we use other than when we are storing it.
    Thx
    Lonnie
  • Thanks but No it's not just the common key fob with "open" & "Lock" pretty basic.
    Thx
    Lonnie
  • My system will do that if a lock is out of sequence. In other words, all locks must lock at the same time. If one lock was manually locked before using the remote, my clearance lights will flash. They will also flash to indicate low chassis battery charge. This is on a 1991 but it might give ideas on items to check.
  • Is your remote locking system programmable? Perhaps there's a flash/no flash setting in the menu?
  • The door is closed, if we use the key to lock the door there are no issues. Only when I use the Key fob do we have a flashing lights. I have cleaned all contacts on the door??
  • It sounds like it see's a problem, like a door isn't shut.
