kmb1966's avatar
kmb1966
Motorhome weighed today. - Need input
We brought our motorhome to have it weighed today. The scales in my area only weight the front and rear axle weights. So far no place to weigh all 4 corners. Here are the weights with water tank 3/4, Fuel 1/2 tank, mostly empty storage bins, 2 passengers when weighing. Propane full, empty holding tanks.
From the CAT Scale:
Front: 6,640 lbs (MAX 7,000 front axle)
Rear: 12,300 lbs (MAX 13,500 rear axle)
Total Weight today: 18,940 lbs (MAX 20,500)
I am using Hercules H-902 245/70 19.5 "G" rated tires with 100 PSI in each.
Tires states: 4540 Single 4300 Dual @ 110 PSI
Is my tire pressure correct? Too high?
Thank you in advance.
