Gundog's avatar
Gundog
Nov 22, 2019
Water fill line leaking how do I access it?
Coach is a 2005 Fleetwood expedition 34H. I am in the process of winterizing and I was starting to fill the fresh water tank with RV antifreeze it is running out as fast as I put it in. The tank had water in it before I started with no leaks I can't tell where it is leaking it is above the frame and leaking down. How do you access the top of the water tank? Yes the drain valve is closed it is not coming from there.
I did this last year with no problem. I usually fill the fresh water tank with the fresh water hose in the bypass mode when I am using the coach normal operation. I am trying to put the antifreeze in with the fresh water port.
