avarusbrightfyr
Jan 05, 2020Explorer
Fresh Tank Filling on City Water
Hello all,
I'm new to this forum and wanted to start by saying hello and I'm glad to be here!
I've been living in my travel trailer for nearly a year now in a trailer/RV park and haven't really been able to use it for the "recreational" part because I don't have a truck yet. Because of that, I've been on city water exclusively since I've had the trailer. A few days ago, I wanted to make sure everything on the boondocking side of things still worked, so I switched over to the RV side on the water selector and filled the tank and ran water through the pump to test things out. Everything seemed to work fine, so I emptied the tank and switch back over to city water.
However, now my fresh tank is continuing to be slowly filled while city water is selected. The rate of fill is much higher when RV is selected and much lower when on city water, so my assumption is that the selector valve is not sealing properly, but I'd like to get some input from more experienced RVers to make sure I'm not oversimplifying. I've read some things about faulty backflow preventers on the pump causing the fresh tank to fill, so I don't want to discount that just because it hasn't been used much at all.
Any input would be much appreciated!
